SEE THIS BUILD - V1 #49
Goblin V1 Specs
The Goblin V1 pairs a lightweight chassis with proven Ecotec power. Browse the specs to see dimensions, powertrain options, and baseline performance.
Powertrain Options
The Goblin V1 uses Chevrolet Cobalt donors, so you can choose a naturally aspirated build or step up to the supercharged or turbocharged SS for more power.
The table summarizes displacement, horsepower, induction, and available transmissions so you can match the donor to your goals and budget.
More Donor Info| Base | Sport | SS/SC | SS/TC | |
| Displacement | 2.2 liters | 2.4 liters | 2.0 liters | 2.0 liters |
| Horsepower | 145 - 155 | 171 - 173 | 205 | 260 |
| Induction | Naturally Aspirated | Naturally Aspirated | Supercharged | Turbocharged |
| Transmission | Auto or Manual | Auto or Manual | Manual | Manual |
Chassis Specifications
The space frame is DOM mild steel for strength, safety, and low weight. Tubing sizes are optimized for stiffness where it matters while keeping the car nimble.
Key dimensions below show how compact the Goblin is, which helps with turn-in, visibility, and easy storage in a small garage.
| Spec | Details |
| Length | 127 in. |
| Width | 52 in. |
| Height | 44 in. |
| Material | DOM Mild Steel |
| Main Cage | 1.5 in. OD x .095 in. wall |
| Rear Cage | 1.25 in. OD x .065 in. wall |
Performance and Dimensions
Stock power ranges from 145 to 260 hp. With a curb weight around 1350 to 1550 lbs, even a base donor delivers sharp acceleration.
The wheelbase, track width, and overall size give the Goblin a planted feel with quick responses on autocross courses and back roads.
| Spec | Details |
| Horsepower | 145 - 260 hp (stock) |
| Weight | 1350 to 1550 lbs. |
| Wheelbase | 97.5 in. |
| Track Width | 59 inches |
| 0 - 60 MPH | 4.7 s. base - 3.25 s. turbo |
