SEE THIS BUILD - V1 #364
Goblin V1 Kit Contents
Everything you need to build a Goblin V1 using a Chevrolet Cobalt or Pontiac G5 donor. The kit focuses on assembly and ships with pre-drilled panels, pre-bent brake lines, labeled hardware, and model-specific parts. You bring the donor components and finishing items like fluids and paint.
See the Donor Overview for compatible trims and a parts checklist.
Packed In Three Stages
You can choose to receive your Goblin V1 in stages so you can build in logical steps or you can choose to receive everything at once. Stage 1 mounts and runs the powertrain. Stage 2 gets the chassis on its wheels with steering and brakes. Stage 3 finishes the car for street or track with body panels, lighting, and optional equipment.
Stage 1 Overview
Stage 1 centers on the uncoated chassis and the parts required to mount and run the donor powertrain. It includes the fuel system, cooling components, pre-drilled floor and firewall panels, and pre-bent steel brake lines that install early in the build.
Stage 1 Parts List
| Part | Base Auto | Base Man | SS/SC | SS/TC |
| Stage 1 Hardware Pack | ✓ | ✓ | ✓ | ✓ |
| Uncoated Bare Chassis | ✓ | ✓ | ✓ | ✓ |
| Automatic Tunnel Cap | ✓ | - | - | - |
| Manual Tunnel Cap | - | ✓ | ✓ | ✓ |
| Radiator Mount Structure | ✓ | ✓ | ✓ | ✓ |
| Front Control Arms | ✓ | ✓ | ✓ | ✓ |
| Floor Pan and Firewalls | ✓ | ✓ | ✓ | ✓ |
| Fuel Tank | ✓ | ✓ | ✓ | - |
| SS/TC Fuel Tank | - | - | - | ✓ |
| Fuel Filler Hose | ✓ | ✓ | ✓ | ✓ |
| Radiator with Fan | ✓ | ✓ | ✓ | ✓ |
| Radiator Hoses and HW | ✓ | ✓ | ✓ | ✓ |
| Coolant Reservoir Mount | ✓ | ✓ | ✓ | ✓ |
| Solid Trans Mounts | ✓ | ✓ | ✓ | ✓ |
| Passenger Kick Plate | ✓ | ✓ | ✓ | ✓ |
| Steel Brake Lines | ✓ | ✓ | ✓ | ✓ |
| Steel Clutch Line | - | ✓ | ✓ | ✓ |
| Shifter Cables | - | ✓ | ✓ | ✓ |
| 2.5 inch Exhaust System | ✓ | ✓ | ✓ | - |
| 3.0 inch Exhaust System | - | - | - | ✓ |
| Heat Exchanger Lines | - | - | ✓ | ✓ |
Stage 2 Overview
Stage 2 turns your project into a rolling chassis. You will add front suspension and coilovers, uprights and rod ends, steering components, and brake assemblies. With these installed the car sits on its wheels and is technically drivable but we recommend waiting for Stage 3 before hitting the road.
Stage 2 Parts List
| Stage 2 Hardware Pack | ✓ | ✓ | ✓ | ✓ |
| Front Coilovers | ✓ | ✓ | ✓ | ✓ |
| Front Uprights | ✓ | ✓ | ✓ | ✓ |
| Front Rod Ends and HW | ✓ | ✓ | ✓ | ✓ |
| Front Brakes | ✓ | ✓ | ✓ | ✓ |
| Rear Brakes | * | ✓ | ✓ | ✓ |
| Braided Brake Hoses | ✓ | ✓ | ✓ | ✓ |
| Master Cylinder Adapter | ✓ | ✓ | ✓ | ✓ |
| Brake Res Adapter | ✓ | ✓ | ✓ | ✓ |
| Steering Wheel | ✓ | ✓ | ✓ | ✓ |
| Steering Column HW | ✓ | ✓ | ✓ | ✓ |
| Toe Link Rack | ✓ | ✓ | ✓ | ✓ |
| MAF Tube | ✓ | ✓ | ✓ | ✓ |
| Silicone Intake Couplers | ✓ | ✓ | ✓ | ✓ |
| Air Filter | ✓ | ✓ | ✓ | ✓ |
| Shifter Hardware | ✓ | ✓ | ✓ | ✓ |
| Heat Exchanger | - | - | ✓ | ✓ |
| Air to Water Intercooler | - | - | - | ✓ |
| Intercooler Mounts | - | - | - | ✓ |
| Intercooler Water Pump | - | - | - | ✓ |
| Intercooler Pipe | - | - | - | ✓ |
| MAP Tube | - | - | - | ✓ |
| Turbo T-Bolt Clamps | - | - | - | ✓ |
| * Indicates part is optional for that donor trim. | ||||
Stage 3 Overview
Stage 3 completes the look and function based on your goals. Street builds typically add hood and side panels, lights, mirrors, and windscreen. Track builds may skip lighting and focus on weight and performance parts.
All Stage 3 items are optional and can be added when you first order or later. If you plan to use large body panels, consider shipping them with Stage 1 to minimize freight.
Kit Contents FAQ
Ordering Info
Configure your Goblin to match your goals. Choose body panels, lighting, suspension options, and more on the order page. The Knowledge Base has details on shipping, lead times, and common options.
V1 Order Page Ordering FAQs-
Ordering Process
1. Obtain your donor
Get the donor first. We match parts to your engine and transaxle so your kit is packed correctly.
2. Order your kit online
Select options for panels, lighting, suspension, and other equipment to fit your build plan.
3. Receive the kit
Choose one shipment or split into three stages based on your budget and space.
